Samsung galaxy note 20 ultra having problem with network after software update
(Topic created on: 25-01-2025 09:52 PM)
Members_Onl4kfS
Hi Community,
I have updated my samsung galaxy note 20 ultra since then I have a problem with the network operator selection, mobile phone unable to find network. Tried to reset network settings, try to add access points, tried changing network operator selection but did not work. Same SIM car is working on iPhone no it seems it's not a sim card problem.
Some how I can't turn off network operator selection to manuall and getting error . Could someone guide me here ?
15 REPLIES 15
A16M
It seems like your Samsung Galaxy Note 20 Ultra may have a software issue or network configuration problem. Here are some steps you can follow to try and resolve the issue:
1. Check for Software UpdatesGo to Settings > Software update > Download and install.Make sure your phone is running the latest software version, as updates often fix network-related bugs.2. Verify Network Mode SettingsGo to Settings > Connections > Mobile Networks > Network Mode.Ensure it is set to LTE/3G/2G (Auto connect) or 5G/LTE/3G/2G (Auto connect) depending on your carrier.3. Reboot into Safe ModeRestart your phone in Safe Mode to see if a third-party app is interfering with network settings.Turn off your phone.Turn it back on while holding the Volume Down button until the Samsung logo appears.In Safe Mode, try selecting the network operator manually again.If it works, an app might be causing the problem. Uninstall recently installed or suspicious apps.4. Reset APN SettingsGo to Settings > Connections > Mobile Networks > Access Point Names.Tap the three dots in the top right corner and select Reset to Default.If your carrier requires specific APN settings, enter them manually.5. Force Manual Network SelectionOpen the Phone app and dial *#*#4636#*#* to access the testing menu (if available on your device).Go to Phone Information > Set Preferred Network Type.Try selecting LTE only or the appropriate network type.6. Check SIM Card and SIM SlotEnsure the SIM card is seated properly in the slot.Try inserting the SIM card into the other SIM slot if your phone has dual SIM support.7. Factory Reset (Last Resort)If nothing works, back up your data and perform a factory reset:Go to Settings > General management > Reset > Factory data reset.After resetting, check if the problem is resolved before restoring your apps or settings.8. Contact Samsung or CarrierIf the issue persists, it could be a hardware problem or a bug specific to your phone’s firmware version.Contact Samsung Support or your network carrier for further assistance.
Let me know if any of these steps help!
4o
Members_tNo0nhK
Hello! I have the exactly same problem, working perfect before the last update and then no network after the update, it is frustating , i am now some hours trying to resetint it many times but not lucky.
ARechy
I am also experiencing the same issue since the last update, it was working perfectly before. Tried most stuff except factory reset, which is very time consuming having plenty of apps to be reset again for security purposes. Not expected such from Samsung they should have tested it well enough before deployment of last few updates for the 2020 series.
aisa74
Hi,
I have the same problem it does not register to the 3 Denmark network. My software is up-to-date ir is a Galaxy Note20 Ultra 5G
Do you have solutions?
aisa74
Hi,
testesteruk
i have the same issue with with s21 ultra after update of one ui 6.1 . it complete broke the network. use different sim cards with different network it does not work even same sim cards with other handset perfectly working fine . did all the settings for reset and all still does not work .
Just for the clarification nothing problem with network provider it is with samsung software as i travelled to different continent and its the same issue with their sim cards and same sim cards are working on other handsets . so it does problem with samsung software. we must need the immediate resolutions. @samsungsupport team look this matter urgently .
vijaykshatriya
Hello Samsung, Pl helpppppppppppp,
My samsung note 20 Ultra 5g , single sim tray was working extremely good since last 1 year. After recent update on 28 april, 2025 broke the network badly. I am facing a trouble for using this phone..Please help. send a remedy, update or do anything to make the beautiful phone work again. Otherwise i'll have to go back to my note10, 5g....which is downgrade. help help help. I am using AIRTEL sim and got it changed as well. did factory reset..nothing works. pl resolve immediately. Thank you for your support. I have been using note series since its inception..you can imagine how much I love NOTE series. SM-N986N is the model name. Thanks again. Godspeed!
vijaykshatriya
..If I switch to mannual selection of network. it shows the service providers which are available. but unable to select as it doesn't connect. just more info..
shayp123
Also have the same problem with the same model. I tried turning airplane mode on and off, but it sometimes works and sometimes doesn't. Please help 😞
