Wifi and data problem
(Topic created on: 20-06-2021 05:39 PM)
walit
After update my phone is going downhill. Wi-Fi and data don't work properly and youtube won't work at all on data. Sometimes I haveto activate and deactivate flight mode and will work at Times but not always. I tried all the steps from google but nothing works.
6 REPLIES 6
xSteveuk
Mastermind
Hi
After a system update
It's always good to
Clear the system cache
https://www.samsung.com/uk/support/mobile-devices/how-do-i-clear-the-cache-on-my-device/
walit
Done ,nothing change
StephK1
Troubleshooter
To help with the data connection, have you tried resetting the APN settings? You can do this in Settings > Connections > Mobile networks > Access Point Names > Reset to default. 🙂
walit
Only solution is a new update , i done new update and so far so good but who knows ...
LiquidSnake
Big Cheese
If all fails, best bet is to move, copy and paste ALL your data to somewhere safe, like a laptop. Then, factory reset the phone :). If this STILL fails, hopefully you are under warranty or a care plan, to get another phone lol.
dkeating
Same issue on my phone and no, that doesn't help. Any other options?
