A9 Phone sound and brightness drop help plz
(Topic created on: 11-08-2020 04:34 PM)
Steeltuff73
My A9 is dropping brightness and sound at the same time
It'
s not adaptive brightness as it's off think it started after last update..
Can someone please explain thanks.
3 REPLIES 3
AsadM
Hi @Steeltuff73
Thanks for reaching out. Are you experiencing this on any particular pages or apps? Is the software on your phone up to date? You can check this by going into Settings > Software update.
Anonymous User
Not applicable
Are you gaming while that happens or something like that? It usually happens if the device overheats
Steeltuff73
I am playing games when I noticed it and the phone is quite hot 🔥. How do I stop this from happening.
