29-06-2024 05:08 PM
- Mute
- Highlight
12-09-2024 07:31 PM
- Mute
- Highlight
13-09-2024 04:38 AM
- Mute
- Highlight
HELLO SAMSUNG I THINK THE PROBLEM IS IN THE UPDATE IT SELF WOULD IT BE POSSIBLE FOR YOU TO CREATE NEW UPDATE FIXING THESE ISSUES, BECAUSE ITS SAD TO SEE THAT I AM A FAN OF SAMSUNG SO ALL MY DEVICES IS ALSO SAMSUNG BUT WHEN THE UPDATE IS INSTALLED ALL MY DEVICES RECEIVED THE SAME ISSUE WITH THE CHARGING
13-09-2024 10:25 AM
- Mute
- Highlight
Hello all!
It seems the issue is still ongoing for a few of you, so I'd definitely advise sending in an error report via the Samsung Members app > Get help > Error reports, with the error log attached. When doing so, please include as much detail as you can, alongside including any useful screenshots and/or videos. If enough people send this in, our engineers will be able to compare the error logs and release an update.
29-09-2024 08:31 PM
- Mute
- Highlight
Hello,
It happened with me, and after reading here that it may be related to software update, I went into the settings >> Battery >> Charging Settings >> Fast Charging (It was on, so I made it off, then I made it on again), then I connected the super fast charging cable, and the charging percentage started increasing until fully charged in a good time. I do not know if it is just a coincidence, or if it is the actual solution. I did not try it for many charges, I just charged it once now and typed this here once it worked. Wish everyone to get this solved.
09-10-2024 10:41 PM - last edited 09-10-2024 10:42 PM
- Mute
- Highlight
My wife has the same phone but hers charges properly, and the difference is in the kernel version
15-11-2024 03:57 PM
- Mute
- Highlight
Mine charges in 9 hours even though I have fast charging enabled
04-12-2024
03:25 AM
- last edited
04-12-2024
01:28 PM
by
ChrisB_
- Mute
- Highlight
Hello sir, I have the solution to your problem. You have to go into security mode on your phone and deactivate rapid charging because the problem comes from super fast charging which no longer responds.
25-12-2024 10:07 PM
- Mute
- Highlight
same problem
honestly its been about two months since i got this problem
sometimes it charges quickly in 2 hours, but only few few times
03-01-2025 11:54 AM
- Mute
- Highlight
Same issue here, any solutions yet?
03-01-2025 11:56 AM
- Mute
- Highlight
