Go to solution Solved
Samsung Odyssey G7 240Hz and FreeSync problem
(Topic created on: 07-10-2023 04:05 PM)
Naralis
Hi, i have a issue with my Odyssey G7 Monitor. As seen in the photos when im using monitor with 144Hz and FreeSync off normally but when i try to open 240Hz or when i open FreeSync my screen is zooming. Im using display  1.4 vesa certified cable. I update last driver  1016.1 and i still have this problem. Can anyone help me please?
Pugs1957
SuperStar
I read something stupid earlier, pull the connector from the power supply and then push it back in.
Crazy or ?
9 REPLIES 9
Pugs1957
SuperStar
Try changing scaling to 100%.
Naralis
How can i change?
Pugs1957
SuperStar
Hold down ctrl key and rotate the wheel in your mouse or the + or - key.
Naralis
Still same nothing change.
Naralis
i think its about monitor software and like a 8 months samsung didnt add new software still using 1016.1
JEDI-22
Just buy another one, because no gives a monkey's
Pugs1957
SuperStar
Crazy or ?
Naralis
Lol its worked !! Tysm man. If I encounter the same problem again and cannot solve it, I will come back.
Pugs1957
SuperStar
Why do you say that?
