Go to solution Solved
Samsung ChromeBook Go - not connecting to a Samsung USB C Monitor
(Topic created on: 30-12-2023 10:17 AM)
Obsydian
Samsung Members Star ★
I decided to keep rather than selling this freebie Chromebook (came with my sons ZFlip5) as i was paying nearly £600 over 3 years for a dreadful school Acer Chromebook which was hardly ever used at school, but it did work with my Samsung USB C M70A Monitor (charge and display).
So frustrated to find the Samsung Chromebook Go is not working (display or charging) when the Acer Chromebook and various Dell laptops work also.
Any ideas anyone?
Reading up it appears i might need and adaptor for display, but then this will not charge.
I assumed the Samsung Chromebook Go would work in my Samsung Ecosystem.
2 Decades Samsung Ownership, If my response helps leave a Like and Accept as a Solution
DAILY: ZFold6, Watch Ultra, Fit3, CL Ace 2, BT-W6, 20,000 Power bank, Smart Tags
FAMILY: ZFlip5, ZFlip6, Watch6 Classic, Tab S8 Ultra, Tab S7 Plus, Buds Pro2, Buds3 Pro
OFFICE: Book2 Pro i7, M70A 32”, Logitech K700, MX Ego, M720 Triathlon, Pop, Jabra Evolve2
AV/GAMING: QN95A 50” TV, Q900A, SW900s, 8 Series TV, LG OLED, M70A 43”, Dell Inspiron G5
APPLIANCES: Jet 75 Vacuum, MC32 Oven, American Fridge, 8 Series TV, LG OLED
SPARES: ZFlip4, ZFlip3, Buds1 Pro, Buds2 Pro, Book2 Pro i5, Level Speaker
MAINTAIN: iPhone 14, iPad Air4, iPad Mini4, iPad Pro1 12.9, Watch6
Obsydian
Seems I solved my issue, turns out that yet another compatible cable drama, i resorted to buying a Google Chromebook certified cable for £20, in the hope i could replace my £30 USB C cable that works with Dell/Samsung Windows, but not Chromebooks.
All along Google and others advised an HMDI adapter which was a stupid idea as then I had no way to keep the Chromebook powered (it only has USB C, nothing else).
Sad i now have around 6 circa £30 USB C to USB C cables, the struggle is real.
Anyway, the new cable is by far the most robust, in construction and the port connection is more positive, for anyone interested the cable is ...
Cable Matters [Works with Chromebook Certified, USB-IF Certified] USB 3.1 Gen 2 USB C to USB C Cable...
1 REPLY 1
Obsydian
