Go to solution Solved
QD-OLED Monitor Cleaning
(Topic created on: 20-01-2025 08:47 PM)
Members_j80eLIG
Please could you clarify cleaning QD-OLED monitors?
Here you suggest 70% ethanol solution for QD-OLED https://innovate.samsungdisplay.com/blog/how-to-clean-a-qd-oled-or-an-oled-screen/ but on your Youtube video you state to only use distilled water? https://www.youtube.com/watch?v=vAgaGRJM9nY
lminvti
Samsung Members Star ★
Hi @Members_j80eLIG and warm welcome 👋
I would only use microfiber cloth for dust or a bit damp microfiber cloth with a bit of water i would not suggest using ethanol, soap, or any cleaning solvent apart from water, as it can potentially damage the screen's protective coating, leading to issues like discoloration, degradation of the anti-glare layer, and even permanent harm, due to ethanol's strong solvent properties
1 REPLY 1
lminvti
