21-07-2020 02:47 PM
Basically without any bumps or knocks; one day I turned my monitor on and it had thin lines running horizontally left to right and stacked downwards so they're parralel. In games it's more noticable causing it to be very difficult too see.
21-07-2020 08:37 PM
Hey @Niklaus, are the lines still visible if you unplug the monitor and plug it back in again? Can you share a picture of the issue on the screen?
28-12-2020 10:25 AM - last edited a week ago
28-12-2020 08:31 PM
Yeah, with no bumps or anything that's the exact problem I got it sent back and they replaced the tsa display or something. Get it warrantied whilst you can but no clue why the monitor does it in the first place... seems quite dodgy... hopefully they can fix it.
