Help I need a monitor repair!
(Topic created on: 10-02-2023 07:21 PM)
Mazarazza22
Hi I live in Northern Ireland. My son has damaged the screen of a Samsung Odyssey Neo G8 S32BG85 and needs a replacement screen. I contacted Samsung authorised repair centre and it was suggested the repair would be too expensive and that was that. Where can I get a repair??
9 REPLIES 9
ChrisM
SuperStar
Hi @Mazarazza22
We're sad to hear this! Is the screen itself physically cracked and non functional?
Mazarazza22
Hi Chris M
Yes the screen is shattered the monior is still working fine.
ChrisM
SuperStar
Have the Service Centre had chance to physically inspect the Monitor?
Mazarazza22
Hi Chris
No they suggested it would be not worth my while arranging the return and repair.
ChrisM
SuperStar
We're really sad to hear this, @Mazarazza22!
Mazarazza22
Chris
I think I might try again and see what they say. Thank you for responding.
ChrisM
SuperStar
Our pleasure!
Members_DJMpdPK
Hello I'm not sure if you'll see this but just to ask did you end up getting the monitor fixed in the end.
My G8 Neo front panel is also damaged but still fully functioning, the repair is much so I was looking at alternatives
Mazarazza22
Hi thanks for the message. The quote I received was £600 (dearer because of the curve) it was better to purchase a newer model. I do think Samsung should look into cheaper repairs. It was just a waste for the environment.
Cheers M
