Samsung TV not pairing with bluetooth Bose sound dock.
(Topic created on: 19-12-2019 02:55 PM)
Raggermuffin
Hi My samsung TV UE50NU7405   Is not pairing with a bluetooth Device.   I am trying to use my bose series11 speakers.   I can pick these up on my samsung mobile and samsung tablet.   As not technical minded I think it must be my tv settings.
I would appreciate some help please.
4 REPLIES 4
AndrewL
@Raggermuffin: If you enable Bluetooth pairing on your speakers, as per the manufacturers instructions, then go to Settings > Sound > Sound Output > Bluetooth Speaker List, are you able to select your speakers from here?
Raggermuffin
Hi Andrew .  No the speakers do not appear in list!
AndrewL
In the user manual for the Bose Series 11 speakers, it mentions that you're able to stream audio from phones and tablets via Bluetooth, but a physical connection is required to connect to a TV (Optical or Coaxial). For more details, please check page 11 of the manual via the link below:
https://assets.bose.com/content/dam/Bose_DAM/Web/consumer_electronics/global/products/speakers/bose_...
Raggermuffin
Thankyou Andrew I will read this.
Kindest regards
