Samsung 950 sound bar demo mode problem
(Topic created on: 08-03-2019 11:32 PM)
Redmo
@I just got a shop display n950 and I cannot connect the rear surrounds or the woofer because when I go into the set up mode instead of Init it displays shop6. I have updated the firmware but cannot get past the shop6 message. I can change shop6 to shop1 through to 7, but cannot switch it off and get to init so that I can pair the extra speakers. Anyone got any ideas? Thanks
5 REPLIES 5
Dawn6
After 2 years my 850 has done this same exact thing...what did you end up doing?
mbonadio
I know this is an older thread - but I just had an experience with shop mode after updating my Q950T firmware to 1019.5.
After the firmware updated the soundbar kept switching source, and cutting on and off. I called support. They couldn't even tell me how to factory reset, as it wasn't responding to the +/- buttons and doing an INIT. So they suggested I ship it back to them. I mentioned to support that I see "shop" message. He said that happens after a reset.
I played around more. I discovered that it was in shop mode. And to get it out a google search showed me to press "-" and hold while power is off. Bingo, I was able to turn off shop mode.
And as soon as I did - buttons started working again, and I was able to do a factory reset, and re-pair my speakers. Since then the  soundbar has been working great - so far!
Really disappointed that they wasted 6 hours of my day, and in 2 hours on the phone with 3 people couldn't solve this - I solved it myself using the internet! Wow! That's sad.
Anyway, the new firmware works well, and it's good knowing that shop mode is a thing! Hopefully my subwoofer pairs on power up now. That was what started all this - and I was furious when they had me update firmware and caused all kinds of issues, and then wanted me to pay to box it up so they could send me a shipping label!  Terrible support Samsung - you can do better.
hazchem
OMG FINALLY! After a week of my TV no longer staying connected via e-arc to my Q950 soundbar, it was because it was in Demo mode. Now to find who's been pressing buttons when they shouldn't. Thank you!
Bobsie
Hiya just jumping on this, how long did you hold down the - for?
Snorkonaut
Hi! I just bought a soundbar which was on display in a shop and encountered this issue! Holding down the  "-" button while the soundbar was off, for between five and ten seconds,  until the lights started flashing!
My soundbar would just all of a sudden go on max volume about every other minute but this seemed to do the trick! Thanks a lot for the help!
