Q70R connection issues for multiple devices using HDMI-ARC
(Topic created on: 23-01-2020 02:25 PM)
SPTuna32
CURRENT SETUP
TV: Samsung QLEDQ70 (2019) 65"
Soundbar: Samsung Q70R - HDMI- Arc output connected to HDMI-Arc:HDMI 4 on TV (HDMI Input port not used on soundbar.)
Devices:
4K Firestick - Connected to HDMI 1 Input on TV
Cable Box - Connected to HDMI 2 Input on TV
HDMI Switch 2.0 (5 Inputs x 1 Output) - Output connected to HDMI 3 Input on TV
PS4 Pro - Connected to HDMI Switch Input
Xbox One - Connected to HDMI Switch Input
Nintendo Switch - Connected to HDMI Switch Input
*All HDMI cables used are 2.0
I have tried mutliple different connections, but am still not sure if I have the best possible setup because I have yet to be able to use Dolby Atmos feature.  Also, when using PS4 Pro, the soundbar auto switches to Game Pro mode. I would prefer it stay in Adaptive mode, but I can live with the fact it switches on its own when Game Mode is detected.  Not sure if thats possible. But the problem I have with this, is that when I turn the PS4 off and switch back to the Cable Box or Firestick, the soundbar will remain in Game Pro Mode rather than switching back to Adaptive mode. I continually have to change it back to Adaptive mode manually. I do get sound and video no matter what device I use with this current setup. I'm just not sure I'm using it to its full potential with devices that are capable of producing better quality sound.
Previously, I had ALL my external devices plugged into the 5 inputs on my HDMI switch. Then the output of the HDMI switch was connected to the input on my Samsung Q70R soundbar. I still was using HDMI-Arc output from soundbar to TV. So the only thing connected to my TV was just the HDMI-Arc connection. This resulted in no picture or sound for ANY device, however I did get sound if I used the apps through the TV itself.
Not sure where to go from here...any help would greatly be appreciated!
1 REPLY 1
ChrisM
SuperStar
It sounds as though this may be one for our Audio-Visual specialists, @SPTuna32. You can give the team a call anytime between 8am - 10pm, 7 days a week on 0333 000 0333.
