q70 tv and q70 soundbar audio delay
(Topic created on: 07-02-2021 11:19 PM)
Ninja_tiger
Hi
I been looking for a solution to this for ages and have spent days talking to Samsung with no real help.
I have a 49q70 tv a ns a q70r soundbar.
When I connect any device to the tv and use passthrough to the soundbar I have issues.
If the sound is set to PCM no problems, except I loose surround. the minute I change the sound to Dolby Digital I get a sound delay about .7 seconds roughly.
ive reset both devices to factory ive changed my hdmi cables to rule them out. if I pass sound to the tv its fine, second its Dolby Digital over arc we get a delay. and Samsung did a EDID reset.
if I connect the device/devices to the soundbars own hdmi input no delay at all.
Also if I use optical to from the tv to the soundbar - there is a delay also.
the Samsung tv apps seem fine. all I can see is a processing issue when device - TV - soundbar is used.
I am at a complete loss what to do. if anyone has any ideas or a place to point me to I would be forever grateful and will buy you a drink..
thanks
1 REPLY 1
Daz73r
Troubleshooter
I have the same soundbar I done a sw update fixed a lot of problems
