No surround sound
(Topic created on: 28-09-2019 06:09 PM)
The1der
Hi All.
I've got my cinema system connected directly from my Sky Q box by Optical Cable but I don't seem to be getting any sound from my surround speakers.
everything is connected correctly (speaker test), I have audio from Front R/L/C & Sub.
Sky Q to Tv (Samsung Series 7) - HDMI
Sky Q to Samsung Cimema System - Optical Cable.
has anyone got any ideas what settings I should have on all devices...???
5 REPLIES 5
SjorsK
Maestro
How did you configure the sound settings in your TV if I might ask?
The1der
In the sound menu or system menu..???
SjorsK
Maestro
Both, I wish to check everything to see if I can see a mistake :smiling-face:
The1der
Tv Sound Menu:
Select Speaker - Reciever (HDMI)
Expert Settings,
HDMI Audio Format - PCM
Audio Format - Dolby Digital
Audio Delay - 40
Sound Feedback - Low
SjorsK
Maestro
Ah, that explains it. Put it on PCM / Bitstream instead of PCM / Dolby Digital.
That should solve it. When you select Dolby Digital it converts the signal to what the TV itself support. But with bitstream it sends the signal as unmodified as possible to the reciever :smiling-face:
