28-05-2021 07:27 PM - last edited 28-05-2021 07:28 PM
- Mute
- Highlight
Hello
I have the Frame 32" connected to a soundbar HW S40T.
The TV remote works well with the Bluetooth connection. However when the soundbar is connected through the optical cable, the TV remote does not control the soundbar. Is there anything special to do to make the TV remote control the soundbar in optical connection ?
Thanks
28-05-2021 08:02 PM
- Mute
- Highlight
28-05-2021 08:05 PM
- Mute
- Highlight
It is connected via optical cable, but the TV remote does not work. It only works in Bluetooth connection
28-05-2021 08:12 PM
- Mute
- Highlight
How strange! Have you tested the steps listed on the link provided above @phnw1 ? If so, do you have any other cables to try to see if they make a difference?
29-05-2021 08:41 AM
- Mute
- Highlight
Hello
it actually works with the main remote but not with the smart remote.
thanks.
