28-11-2017 10:46 AM
Hi, updated my watch and since its been done I have found the battery life decrease significantly more than before, I used to get 4 days without allways on screen now im only getting around 1-2 days max. Has anyone else been having this issue since the new update ?
Thanks
28-11-2017 11:04 AM
It can take a short while for the watch to settle after an update @TDazza123
Assuming that you've not downloaded any new apps that maybe using more resources it could also be your watch apps optimising.
If this continues then a last resort could be to factory reset the watch.
Daily Driver > Samsung Galaxy s²⁴ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
28-11-2017 11:53 AM
Same issue, left it to settle just got worse, reset the watch, the same, reinstalled the app and reset the watch - the same.
For my the weather app, samsung pay and the new update have took a 3 day battery life to 1.5 days if lucky - a disaster.
Samsung you have taken a GREAT product and ruined it
28-11-2017 12:17 PM
Hi ,
Thanks, I do think that myself, always seems to be teething problems with new OS so I will wait it out and see how it goes. Hopefully battery improves
28-11-2017 12:18 PM
I wouldn't go as far as they have ruined it but yes it is a little flustrating, we will need to allow time for the watch to settle with the new OS
12-12-2017 03:34 PM
Same ***** from 4 days to one. Done fresh start and after a while, 2 or 3 days starts to drain again. My first Samsung and probably my last
12-12-2017 03:34 PM
Same *****
12-12-2017 03:36 PM
