Go to solution Solved
Gear S3 timer no sound since update.
(Topic created on: 28-11-2017 11:28 PM)
Bannyla
Since the update my Gear S3 countdown timer has no sound. Any ideas?
Tags (4)
Bannyla
Yes. Found it myself. Go into the Gear App then select settings then apps. The timer app had an exclamation mark on it saying it needed updating. Updated it and it was sorted. Hope this helps!
5 REPLIES 5
BandOfBrothers
Have you tried a soft reboot by turning it off and on.
Daily Driver > Samsung Galaxy s²⁵ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
Xn30x
I have the same issue. Any fix yet?
Maxwel23
Hello,
Gear S3 timer no sound since update, Gear S3 timer no sound is a problem fo me also.
On the other post, I make:
1 : From the Gear application : unistall the timer application
  • Force STOP  less than 30 Seconds.
  • Unistall
  • Go to history of applications always on phone
  • Find Timer
  • Install it.
Work again  for me!
Hope for you too.
Samsung galaxy S7.
Samsung Gear S3.
Re: Timers not working on Gear S3
Bannyla
emanpharma
I found it myself .
Go to watch . then go to settings and then accebiltiies . then Audio enhancement there must be enabled mute all sounds disable it.
