22-02-2023 04:24 PM - last edited 22-02-2023 04:31 PM
Hi All I've noticed something extremely annoying with the Samsung Galaxy Watch 4. Often in a rush leaving the home I'll grab my watch from the charger 100% charged, If I wear it and forget to go through the security pattern in like 3 hours the battery drains to about 20%. However, if I remember to go through the security unlock once on my wrist, the battery lasts all day. Can Samsung fix this please. It's really annoying!!
02-03-2023 04:41 PM
Try updating.
02-03-2023 04:42 PM
I think they solved this issu
02-03-2023 09:59 PM
I keep it upto date. Literally happened to me yesterday morning again. Put on my wrist 9am, by 12pm no battery. Switched it on, didn't go through the security pattern. Battery drained to 0%.
03-03-2023 02:56 PM
Hi @Ziizii ,
I have located this guide from our colleagues in the US. Can you have a look at the steps there to see if they help with your battery issue? You can access this from here: Reduced battery life on your Samsung smart watch
08-01-2024 01:04 PM
Hi
I have this issue to, it's infuriating. Did you find a fix?
08-01-2024 01:10 PM
29-08-2024 11:22 AM
