Go to solution Solved
Overheating problems with Galaxy watch 7 pro
(Topic created on: 28-08-2024 10:47 AM)
Rix2372
Yesterday I put my watch charging and went I was checking my notifications I noticed that the watch was desconect from phone that was I realised that watch was off for overheating this is third time this happened.
It's my watch the only one or anyone else have the same problem?
I had all Samsung watches since they begin and this is the first one to happen this.
Weird.
TechZilla
Samsung Members Star ★
He means there is a Galaxy watch ultra or Galaxy watch 7, your title says Galaxy watch 7 pro which doesn't exist. So I suspect that Samsung wireless charger is not fully compatible with your new watch because the same thing has happened with my Galaxy Watch 6 classic a couple of times. I would just use the charger that came with the watch then you probably won't have the problem
TechZilla - Samsung Members Star
9 REPLIES 9
GoanGeek
Hi.
My watch 6 does warm up a bit while charging but nothing extreme like yours.
I don't use it while charging and it's much cooler her in the UK ATM.
Also I charge it in the morning everyday regardless of how much h battery is left as then I don't have to charge it for too long.
Follow Me, like my posts and Mark as Solution if I helped solve your Problems.
Daz73r
Troubleshooter
Pro or ultra 🤔 they didn't make a 7pro are you using lte
TechZilla
Yes it is a safety measure to protect your watch. Also which charger are you using?
Rix2372
Samsung galaxy wireless charger
Rix2372
Pro
Rix2372
What you mean they didn't made Samsung Galaxy watch 7 pro?!
Daz73r
Troubleshooter
Pro5 6 classic then ultra
TechZilla
Daz73r
Troubleshooter
