iconx battery drain
(Topic created on: 21-01-2020 02:43 PM)
Utkudemir
I have earbuds model SM-R150 and cardle EB-PR150. I insert the buds inside of the cradle and close the cover, and fully charge. I remove from the charge and put it on the shelf. After few days even I never use its battery become empty. I feel it does never turn off.
7 REPLIES 7
AntS
Hi @Utkudemir , :smiling-face:
I found this general guide for the IconX on our website: https://www.samsung.com/uk/support/mobile-devices/set-up-and-use-the-gear-iconx/
From what you've said, I'm wondering if a restart on the buds will help. :thinking-face: From that guide above:
Utkudemir
Thanks, I will try.
Utkudemir
Didnt help.
CarlH
Utkudemir
Yes, during usage I connect it to the phone and use them without any problem. After usage I switch off all nearby bluetooth devices, I recharge and put them on the shelf as the future usage. After few days, I find the device with an empty battery.
AntS
No worries. Cheers for trying that out and getting back to us, @Utkudemir. I reckon that if a reset had no effect at all then it's best to get your  buds and cradle checked out at your nearest Samsung Support Centre.
OldManMeadows
Did you manage to fix the problem @Utkudemir? I have the same issue with mine. Since I bought them almost three years ago I do not have any warranty anymore. @AntS.
