26-03-2019
09:27 AM
- last edited
17-05-2019
01:41 PM
by
AntS
My Gear S3 (D786) has been zooming in for no reason for the past few weeks. Sometimes it makes it hard to use the watch as it zooms almost every time I look at it. I reset it often but it doesn't help. I've changed the screen back to a Samsung face but it still does it. My watch does not have a 'zoom' setting that I can find & this was confirmed at a Samsung store, so I can't just turn off the zoom function. The watch is about 16mths old.
05-07-2019 03:01 AM
@KimSung wrote:My Gear S3 (D786) has been zooming in for no reason for the past few weeks. Sometimes it makes it hard to use the watch as it zooms almost every time I look at it. I reset it often but it doesn't help. I've changed the screen back to a Samsung face but it still does it. My watch does not have a 'zoom' setting that I can find & this was confirmed at a Samsung store, so I can't just turn off the zoom function. The watch is about 16mths old.
Me too! It is so annoying and constant. Rebooting helps for a minute, but it’s soon doing it again. Please help before I throw this piece of ***** in the trash can!
25-07-2019 07:33 PM
If you tap 5 times on the screen, its gone.
03-09-2019 06:19 PM
THANKS THATS AWESOME!
06-12-2019 09:46 AM
Hi you need to go to settings, accessibility, visibility enhancement and the turm off zoom.
28-03-2020 01:31 PM
Thanks! It worked 😊
14-04-2020 05:15 PM
Thank you for your help!
16-06-2020 04:09 PM
To correct the zooming issue, you must do it on your phone through galaxy wearable app, under accessability, visibility enhancements, zoom off
