Go to solution Solved
Gear s3 won't automatically reconnect to bluetooth when back in range.
(Topic created on: 18-01-2017 02:50 PM)
Chris_N
Hello wonder if you can help.
I have just purchased a Gear s3 and I have it paired and connected to my iPhone 6. The watch works perfect until I become out of Bluetooth range and thus my watch will lose connection, which is as expected. The problem comes when I’m back in Bluetooth range i.e. back with my phone the gear s3 will not automatically reconnect like other devices I have left it 30mins plus and it still won’t automatically reconnect. I have to manually keep turning Bluetooth on and off on both the watch and phone and then clicking on both the Bluetooth connections on my phone (Gear S3(DC10) & Gear S3(DC10) LE) to try and get it to reconnect eventually after going through this process multiple times it will finally connect again. Any help will be appreciated as I can’t keep doing this every time I’m away from my phone. Thanks In advance.
Tags (2)
2 Solutions
leogcalegari
Correct. I had the same issue...tried to reset my gear and also re-installed Samsung Gear app and nothing... until I decide to clear the cash for the bluethooth and now it is back...
Critic4U
Tried your fix and it worked. Thanks Bud.
For others that have no idea where to go to clear the cache and need some help (This is only for Andriod because I do not own a iPhone.) goto Settings > Apps > tap the three dots in the upper right hand corner and select "Show system apps". > Scroll down to bluetooth and tap on it > tap on force close > tap force stop on the pop up > tap storage > tap clear cache > your phone should reboot the bluetooth and connect to the watch at this point. (If it doesn't > go to the gear app and tap connect, it should be the last time you have to.)
I did this and it worked for me I tested it left my phone in the house walked out to the street (25 feet) it disconnected, I walked back in and it reconnected; in fact, I went out in the back yard about another 25 feet away and stayed outside for about twenty minutes came back in and it reconnected.
Before I did this I would constantly have to keep going to the gear app and tap on connect.
Hope this helps.
157 REPLIES 157
AntS
Hi Chris_N. :smileyhappy:
Have you tried a light reset? Settings > Connect to New Phone. Remember to back up any data before: Settings > About Gear > Backup and Restore > Backup Data (and restore from Settings > About Gear > Backup and Restore > Restore Data).
Obsydian
Samsung Members Star ★★
Same here very ****** annoying
2 Decades Samsung Ownership, Follow me on Instagram Obsydian_SMS
DAILY:  ZFold7, Watch Ultra, Fit3, Buds2 Pro, CL Ace 2, BT-W6, 20,000 PB, Smart Tags
FAMILY: ZFlip7, ZFlip6, Watch8, Tab S8 Ultra, Tab S7 Plus, Buds Pro2, Buds3 Pro
OFFICE: Book2 Pro i7, M70A 32”, Logitech K700, MX Ego, M720 Triathlon, Pop, Jabra Evolve2
AV/GAMING: QN95A 50” TV, Q900A, SW900s, 8 Series TV, LG OLED, M70A 43”, Dell Inspiron G5
APPLIANCES: Jet 75 Vacuum, MC32 Oven, American Fridge, 8 Series TV, LG OLED
SPARES: ZFold6, ZFlip5, ZFlip4, Buds1 Pro, Buds2 Pro, Book2 Pro i5, Level Speaker
MAINTAIN: iPhone 14, iPad Air4, iPad Mini4, iPad Pro1 12.9, Watch6
Socal_scorpio
Mine just started having the same problem after the gear software update. I gave the s3 Frontier and note 5
Peter1980
I also have the same issue after gear update.....
s6 with gear s3 frontier
Obsydian
Yes very annoying assumed the latest gear watch and manager auto connect would resolve this, no difference and dangerous trying while driving to reconnect so I don't forget later.
Really is making my watch Useless as I put my phone to silent when using my watch so I don't get two notification vibrates  (phone and watch), but sometimes I'll go a whole morning before realising the same watch is not even paired.
Needs an auto reconnect !!!
Chris_N
Update on my original post, tried several resets\re-pairing to phone but after a few months and software updates still the same problem persits... The whole time i have had the watch it has NEVER reconnected...
Obsydian
Same here I did a full reset to both watch and gear also upgraded to nougat and did the same - Samsung just gave the lame please update, well dahh that does not work.
protie
Same problem here. Kind of pointless to wear watch when it seems to always be disconnected... unless I manually reconnect it. Annoying
titbazax
ye was ok till last update same promblem here too
