Gear fit 2 alarm
(Topic created on: 22-01-2017 08:29 AM)
Pete
Until last week the alarm on my gear fit 2 was vibrating on my wrist when it went off. There must have been some faulty update as it now isn't doing this any more so unless I am awake and staring at my wrist I will not know the alarm is going off (sort of defeats the object ☺) I have tested the vibration and both the timer and normal notifications are fine. Any background/fixes appreciated)
2 REPLIES 2
JessL
Voyager
Let's get this sorted for you, @Pete!
In Gear Manager on your phone check the Notifications Manager to see if the Alarm permission is turned on.
Also, have you checked if Do Not Disturb is on?
Starflyr
The Alarm clock function is one of my favorites.  Occasionally my Gearfit 2 Pro need to be reset and every time I do it, I have a hard time finding what block the alarm clock is (digital, analog, collarorations, Sports/health, art, interactive, informative or others.   Anyone know which block the alarm is in?
