Go to solution Solved
Gear S3 not vibrates with viber since android 8 oreo
(Topic created on: 16-02-2018 12:46 PM)
laci
Hi
We have 4 galaxy S8 phone in the family and friends, but since andoid 8 oreo update, the gear s3 stopped vibration with viber (only silent notification coming). Why?
The phones and the gear s3 were either factory reseted (without backup) but not helped. All the phone and gear apps are updated.
Yellow dot is perfect! With andoid 7 it was perfect...
The oreo built in samsung gear end gear s plugin does not supports anything?
Ps.: some friend says the gmail and mymail app has the same problem.  All the other apps perfect. We do not understand. :smileysurprised:
2 Solutions
jimdagan
After todays update of gear manager all works fine. Viber and gmail vibrates again,,😁😁😁😁
Grappler
everything working for me to, :smileylol:
35 REPLIES 35
laci
And sound either not works like vibration. There is only silent notification with viber(yellow dot)...
laci
Grappler
I have the same problem on my gear sport, did you find a solution?
laci
No 😞
Grappler
And samsung wont even reply for two weeks, thats a shame.
DenizA
I use S8 and Gear S3, I have the same problem and I've been looking all around the forums and stuff but there is no solution. It all started with Oreo update. Now Gmail and Viber doesnt vibrate. I dont really know what to do.
laci
Me neither.
Write to the developer of Samsung gear app.
DenizA
I just had a long chat with Samsung Support, they have no idea how to solve that either..
AntonioLima
Same issue with other apps on my Gear S3 + Galaxy S8 since Oreo update.
Regards from Brazil, Antonio.
