Gear S3 battery drain after last update, resetting doesn't help
(Topic created on: 11-01-2023 10:19 AM)
matelko64
I tried everything in this post and nothing worked, I reset the watch, I uninstalled the barometer app and none of it helped. I will note that the battery life never got better, it was equally terrible the whole time (even after the supposed 7 day sleep period).
If there is anything I'm missing, please tell me. Otherwise I'd like to know if there's a way to downgrade the os to the last version where I had no issues.
9 REPLIES 9
TessM
Mastermind
Hi @matelko64 ,
I am sorry to hear that you are having issues with your Gear S3 battery. Would you be able to let the battery drop under 50% from a full charge and send us a screenshot of the battery usage? This is available from the Samsung Wearable app> Settings > About Watch > Battery.
matelko64
Thanks for the reply.
Here's the usage:
PaulM1
Thanks for sharing the screenshot, @matelko64. Watch faces seem to be consuming more battery life than I would expect. Are you using a static watch face or a moving one?
In the meantime, I'd recommend consulting the guide below, written by our colleagues from Samsung US:
https://www.samsung.com/us/support/troubleshooting/TSG01003232/
Please let me know how it goes.
matelko64
From the list you gave me I already tried everything and nothing really helped.
I'm using the Gear Dashboard watch face:
One weird thing I noticed about Watch Faces is that I used to have a watch face called Samsung Gold installed on my watch, but it disappeared after I reset it. Don't know if that helps in any way.
I don't know if Watch Faces contain the display's power consumption but if it does then another thing is that when I was replacing the battery (no, it's not in the battery, the old one is even worse) in my watch I probably somehow damaged the display because it has a streak of brighter pixels going down the middle of it. Don't know if something like that could increase power consumption but I'm just telling you everything I noticed.
matelko64
Okay, I did a reset while not backing up and restoring Watch Faces. I'll update you in a week if it worked or not
matelko64
So, it's been a bit more than a week but still it didn't help. Battery lasts pretty much the same amount of time.
I however found something really interesting.
Just a 1% drop totally changed the statistics (the screenshots are like within a few minutes from each other).
I'm totally lost, can someone please help me?
matelko64
Please I'm desperate 😩
Members_cFRoE1x
I am having the same problem with my Samsung Active Fit 2, which I got exactly 2 years ago today for my birthday.  There is huge battery drain, I've switched off all the bits and bobs and I was planning to get a new battery to see if that sorted the problem.  I suspect Samsung just want us to throw away our devices and buy new ones.....shopping around now for a new smartwatch.  And it might not be a Samsung!
Nom1
There's a apkapp to down grade the OS to an earlier version. I had to do this to connect my S3 Frontier to the S24+
I was having a big problem with battery draining. Backed up then reset the phone a couple of times. Restored the watch and switched to a simple screen, then disabled some of the apps running in the background. My S3 Frontier battery life is now amazing 😊
