Go to solution Solved
Galaxy S3 frontier battery drain after last update (GPS)
(Topic created on: 03-09-2022 07:38 AM)
Ayman82
Last week my S3 Frontier did the last software update (GPS) after that the battery suddenly starts plummet from 100% to 10% in less than 8 hours, I reset the watch many times and no result, It is definitely a bug in the update, I'm so frustrated, These bugs indicate the weakness of this company.
FIX IT IF YOU WANT TO KEEP OUR RESPECT
Andy3
Voyager
If you reset the watch you need to give it at least 7 days to settle. Like a phone it needs to work all the apps you most use and put the rest into deep sleep. Battery usage will be high after a update or reset for 7 days
5 REPLIES 5
Andy3
Voyager
najeb3
Yesterday my Gear S3 watch battery started to drain so fast. I have not touched the watch and the battery went from %53 to %0 in 3 hours and a half. What a shameful display! What a ***** update!
This has to be fixed ASAP.
Ayman82
Really after one week the watch returned as it was, it's working normally and taking about 3 days until I need to recharge it again. But I did'nt understand what is the secret of that issue.
Andy3
Voyager
It's no secret. It takes 7 days to put apps to sleep. It needs to learn usage patterns.
XTREMEBASE
Disable/uninstall/delete Barometer app.Update activated it again.
