Gear fit2
(Topic created on: 16-08-2020 07:08 PM)
Members_QcjmQdO
Good evening all.
I have a gear fit2.
It was working absolutely fine up untill this afternoon, when the battery died. It has been on charge for a couple of hours, however it will not charge the battery, boot up or do anything.
I have tried all the tips on taking it on and off charge, pressing the power button for 30 seconds, cleaning the contacts etc.
The charger is a known working one as it charges my wife's watch.
I think the battery has stopped working.
Has anyone else had the same issue, keen to see if there is a pattern.
2 REPLIES 2
CarlH
Hi @Members_QcjmQdO. Is the charger the original one that came supplied with your Gear Fit2?
gadge442
Have you tried pressing both buttons simultaneously for 30 seconds?
