Gear Fit 2 problem
(Topic created on: 22-06-2017 07:02 PM)
ElkeB
I have just placed my Gear Fit2 onto the charging dock, but it is not charging.  I have tried various sockets and laptop USB ports but nothing seems to work.  I have only had it for less than a month as it was a birthday present.
I did do an update overnight and it was working before the update, has anyone else experienced the same problem???  If so what did  you do about it???
1 REPLY 1
DRUIDDOODE
Voyager
Hi,make sure that on the back of your gear fit,the four holes on the back are clear of gunk,even tiny bits of dust even skin cells build up over relatively small amounts of time
Your gear monitors your exercise so sweat is expected but it must be cleaned I do mine nearly every time I charge to make the process easier and make the overall life time of my gear last longer
As sweat is corrosive especially on the gold contacts
DRUID DOODE
