Go to solution Solved
Galaxy Watch 46mm Battery Drain after Update
(Topic created on: 23-03-2021 01:21 PM)
Phil Lindoe
Could someone please advise on what is going on.
I used to get up to 4/5 days usage out of my watch. I had an update yesterday, after the update the watch wouldnt charge.
I turned it off and back on again and it would then charge, problem over I thought.  Now the battery drain is extreme.
I woke up this morning and it was at 15%.  Charged it up to over 60%, went out for a walk and now down to 35%.
Back on charge.  This is ridiculous.
How can I reverse the update and see what the battery performance is like then?
2 Solutions
Phil Lindoe
I backed up my watch via the app then uninstalled the connectivity app and the gear app
Reset the watch
connected the phone back to the watch (took a while as I didnt delete the connectivity app at first - this seemed the key part)
Now the battery drain is back to normal
Suggest those struggling try this.
Not sure why Samsung arent doing anything about this  😞
Phil Lindoe
This is where mine was stuck for ages
Make sure you uninstall all the gear apps and addons and reinstall
I do remember having to do this ages ago now, its a pain in the a55.
If you just reinstall the gear wearable app and try to connect it will ask you for the companion app or connect addon.
33 REPLIES 33
Alfsdad
Voyager
I did the update on my watch yesterday. Charged it up yesterday afternoon following the update. Showing just now 74%. Working OK. I did check all the settings on the watch and in the Wear App to ensure nothing had been altered.
Phil Lindoe
Did you charge up to 100%?
Not sure why it should change any settings, but not sure what settings would cause battery drain like what I have experienced?!!??!
Alfsdad
Voyager
Yes charged up to 100%. I have a sim card in the watch connected when needed to 4G, then when at home to the WiFi. I normally charge mine using it this way every 2½ to 3 days. One of the updates in the download was the way Notification function works and also now linking the watch to Smart Things App.
Phil Lindoe
Well not working for me.
Just charged to 100%, now down to 87% and done nothing
Need to wind it back a firmware, not sure how to?!?!?!
Alfsdad
Voyager
Unfortunately that's something I don't know anything about. Never had to do this with any of my Samsung phones etc over the last 10 years.
Just a thought have you tried switching of the watch then restarting it. There was also a number of Apps for the watch to update in the Galaxy Store.
Phil Lindoe
Yeah, had to do that after the first update as it wouldnt charge.  The restart sorted that out.
down to 76% now after doing nothing special with it.  Something is defo wrong here.
Thanks for the help though :thumbs-up-sign-emoji-modifier-fitzpatrick-type:
Alfsdad
Voyager
Sorry I did not have the answer. Good luck.
Phil Lindoe
IS your HR monitor set to continuous or every 10 mins?
Just noticed it was set to continuous, not sure what it was before this?!?!?!
Cheers
LJF2
My Galaxy watch is the same, wouldn't charge so tried a different charger. Managed to get it up to 73% 50mins later it is on 15%. I did the update this morning
