Galaxy Buds3 Pro Charging Status Light
(Topic created on: 10-10-2024 11:10 AM)
Tyla
Hey guys, I know the indicator light on charging case is supposed to indicate the case's battery status for 5 seconds after it closes (red for <30%, yellow for <60% and green for >60%), however mine is always red, despite the popup confirming case power is at 79%. I've seen it flash green (and blue) when in pairing mode etc, but it's always red for battery. Any ideas to stop me overcharging by constantly worrying the case is dying before being able to check the popup?
Thanks!
8 REPLIES 8
KholaI
Hey @Tyla
It's a little odd that the light on the charging case is constantly on red. Have you tried resetting the Buds to see if this makes a difference at all? If not, you can do this by heading into the Galaxy Wearable app > Ensure the Buds are connected and the case is open > Earbud settings > Reset > Tap on Reset again. Once you've reset them, you'll need to pair your phone with the Buds again, but you can easily do this by keeping the app open on your phone > Start > Select the Buds when they appear on the screen.
If the issue still persists, your charging case may need an inspection, and you can arrange it via the following link: https://www.samsung.com/uk/support/repair/
Tyla
I think i figured it out - the light is constantly red because the buds are constantly charging in the case. In order to know the status of the case itself, you have to remove the buds, THEN close/open the case with the buds removed in order to see the indicator for the case's charge!
Bishop10
Pathfinder
No need to open/close case just press the button once without the buds in and it will tell you. Likewise with buds in press once it will tell you charge state of earbuds
pete991
Just picked up new buds pro 3 - however when the buds are at 76% i put back into case - the light indicates erroneously RED.
I have updated the software and also reset twice. Brand new so buds connection the case is clean.
Why is it always RED ?
PaulM1
Hi, @pete991. It's possible I've misunderstood what's happening here. However, a red charging light on the Buds3 Pro indicates that the earbuds are currently charging. As your Buds were sitting with a battery level of 76%, the charging light would be red until the level reaches 100%  (if it's charging at the time).
Otherwise, the following status applies:
  • Red light: Buds charging or low battery is indicated.
  • Solid red: Usually means that your Buds are actively charging.
  • Blinking red: This may indicate a charging issue or low battery in the case itself.
I hope this reassures you.
pete991
Thank you Paul
Sorry I didnt realise it was different to my Buds Pro which had amber.
Appreciated
Best Pete
Em-25
The manual says this:
The charging case’s battery power is low (between 10% and 29%), and the earbuds are charging.
This is quite confusing, as one would think their case is between 10% and 29% when it's 80% (in my case). instead, the manual should say ''or''  not ''and''.
Also in your explanation yuo make a distinction in Red Light and Solid Red, what's the difference? When I put my buds in the case it stays red for 5 seconds even though the case is at 80%.
Members_2nQVn02
Try to smack it to your knees or wooden surface like old times! For many people worked! No explanation just worked...🤷🏻
