26-10-2019 12:01 PM in
WearablesHi there,
I have an issue with my month old Galaxy Earbuds case. Quite often the LED both in the inside and outside dont work/show battery status. It does turn itself on when case pluuged in.
Am doing something wrong? Does it mean there is 0 battery juice in the case itself? Is it faulty?
Many thanks,
Bogda
27-10-2019 04:43 PM in
Wearables29-10-2019 07:54 AM in
WearablesI think you'd better use the wireless charger.
I just got a same issiue but I solved that w/ wireless charger
28-12-2019 10:13 PM in
WearablesHi, i have same problem, but i dont now how to disconnect the charger
from the charging case and reconnect it.
Can you help me by telling how to do it or give a link for a tutorial?
29-07-2022 04:40 PM in
WearablesDisconnect the charger means - unplug the cable, and plug it back in.
