Automatic ambient sound with sufficient volume
(Topic created on: 26-10-2019 11:40 AM)
Toorgmot
Hi Samsung,
I would really like to enable ambient sound automatically when I put in my earbuds, without going into the app and switching it on every time I use my buds.
Also, ambient sound has a rather low volume when it is on its maximum. Why can't it be amplified more?
Kind regards,
Tom
2 REPLIES 2
SaudA
Troubleshooter
Hi @Toorgmot, it has been a while since you posted this, so just checking in.
We can look at feeding back your suggestion about Ambient mode coming on automatically.
However, with the issue of low volume, is the problem still there? If so, is it persistent or does the low sound come and go depending on where you are etc?
Toorgmot
The volume of the buts are not low in general. Just the ambient sound, when on max volume, has a relatively low volume compared to the rest of the sound.
