Earbuds battery
(Topic created on: 11-01-2021 01:25 PM)
Roberto_C93
Hi,
I bought the earbuds live and they work just fine
My question is, should i let the battery drain before putting it back on the case or can i put it back regardless of the battery percentage?
For example, if its on 70% left of charge is it okay to put it back in the case and let it charge back too 100%?
Thank you!
4 REPLIES 4
SirStottalot
Pathfinder
Yes you can put back on charge. Not sure with earbuds but with phones you should drain first then a full charge.
Roberto_C93
even if the battery is still on 70%? thats my concern... dont wanna damage it
SirStottalot
Pathfinder
it won't damage it as such but may decrease battery performance, as in charge won't last as long. Personally I would just let them drain 1st but I understand you may want to take them out with you and keep them protected. Maybe overnight connect them to something playing music with volume down to drain the battery.
Roberto_C93
great, thats the answer I was looking for :smiling-face: thank you.
