05-10-2023 03:19 PM
- Mute
- Highlight
- Tags:
- GalaxyWatch5pro
05-10-2023 04:14 PM
- Mute
- Highlight
@AndreescuD: The solution depends on which device you would prefer the alarm to sound from. On your watch, please head to the Apps menu > Alarms, then select 'Add on watch' to set an alarm that only goes off on your watch. To sync with your phone's alarm settings, select 'Add on phone'. To turn off an alarms that is sounding on your watch, drag the X outside of the large circle, or rotate or swipe the bezel.
05-10-2023 04:37 PM
- Mute
- Highlight
05-10-2023 07:32 PM
- Mute
- Highlight
05-10-2023 07:45 PM
- Mute
- Highlight
Since the alarm is synced between the phone and the watch, it will ring on both. If you turn it off on one, it should automatically turn off on the other device.
If you don't want the alarm to ring on your watch, then first turn off all the alarms on the phone. Then head to Notifications in the Wearable app Settings and toggle off the Notification setting for the clock. This will stop the syncing of alarms between the phone and watch.
Turn on the alarm/s the phone.
Hope this helps.
12-10-2023 03:05 PM
- Mute
- Highlight
11-12-2023 07:00 AM
- Mute
- Highlight
27-11-2024 06:19 AM - last edited 27-11-2024 06:20 AM
- Mute
- Highlight
