Go to solution Solved
Whats with the lack of quality small tvs?
(Topic created on: 19-08-2018 04:42 AM)
Mrowin
Bigger does not always mean better samsung, 40in is perfect for my bedroom where I watch most of my netflix. But you never seem to put anything fancy or cutting edge into tvs that small.
Consider a more premium line of smaller sets please.
2 Solutions
AndrewL
Hi @Mrowin
While the Samsung flagship Q range of TV's start at 55" you can still find some great options such as the 43" NU7400 Dynamic Crystal Colour Ultra HD certified HDR Smart 4K TV, details of which can be found by checking the following link: https://www.samsung.com/uk/tvs/uhdtv-nu7400-eu/UE43NU7400UXXU/
JAMES4578
Samsung Members Star ★★
Premium lines really need larger sets for best experience but you should still find some decent sets in the 40-43 inch range, may not be universally  popular but  generally fairly  limited options for smaller rooms nowadays.
In addition to @AndrewL 's   recommendation  other reviews here.  https://www.rtings.com/tv/reviews/best/by-size/40-42-43-inch  US MU700 is the MU6400 in the Uk  a 2017 model which you may also wish to consider, some info here   https://www.samsung.com/uk/tvs/uhd-mu6400/UE40MU6400UXXU/https://www.displayspecifications.com/en/model/d61db42
2 REPLIES 2
AndrewL
Hi @Mrowin
JAMES4578
