Go to solution Solved
Region settings when switching on TV
(Topic created on: 18-08-2018 06:49 PM)
Grank
Hi, every time I switch on my TV it asks for region. If I type in my postcode and set this I get really poor signals and have to reset whole TV. If I skip past this the signals are great and my region is actually correct. So question is - can you turn off this request for region/postcode please?
Thanks
Grank
AMS2
settings
Broadcasting
Auto Tuning Settings
Standby Auto Tuning - Turn this option off
ensure you are on live TV or you may find the option is greyed out
Should solve your issues stops the TV from trying to auto tune for your region whilst in standby mode
9 REPLIES 9
ChrisM
SuperStar
Hi @Grank.
Could you give us the model code and software version of your TV? Go to Menu > Support > Contact Samsung or alternatively, Home > Settings > Support > About This TV.
JordanW
Hi,
My Samsung 7100 series TV also does this; every time I switch it on, it asks me to confirm my region.
Grank
Hi
Model code: UE50NU7470
sOFTWARE: T-KTM2DEUC-1103.5, BT-S
Thanks
Grank
J11griffiths
I have got the same problem with tv that I bought 2 weeks ago. How do you fix the problem?
AMS2
settings
Broadcasting
DannyT
Hi all.
It's worth trying the steps above provided by @AMS2. However, a new update has also been released recently that may sort this issue out.
Welcome to the Community!
PAtrader
Same problem with my new QE65Q7FN, solved by AMS2 suggestion above, but obviously needs fixing in a software update.
Clammer
Same with my Q9F Samsung TV
Anonymous User
Not applicable
Same with my 75q9 as well
