on several sites, ao.com for example, the 75" ue75tu7000 is sold as well as the ue75tu7100, aside from a £100 price difference i cant tell any difference in the specs, can anyone tell me what, if any there are?
The tu7100 is the slightly newer model so may have slightly better processors or just general specs. However the screen quality is the exact same. If i was you I would 100% go with the cheaper one of the two and try to find some discount codes online to get it even cheaper. Plus if you are a student you get 10 to 15% of almost everything on samsung website
