Go to solution Solved
Slow download speeds (Q80T QLED 4K HDR Smart TV)
(Topic created on: 30-08-2020 03:10 PM)
JRPD
I've just purchased the above TV, and am getting slow download/streaming speeds - 12mbps on speedtest.net, 6mbps on Netflix). A laptop placed in the same spot is getting 70mbps, so it can't be the wifi, router or broadband speed.
I've checked for TV software updates.
I notice that other people have reported similar issues over the years - does anyone have any solutions?
Thanks for any help you can offer!
JRPD
OK, I've solved this one, and it was due to my ignorance...
6mpbs on Netflix was giving me what Netflix said was 2160 resolution, when I was expecting 4096. But turns out that Netflix measure resolution vertically not horizontally, so 2160 is full 4k.
Learn something new every day...
4 REPLIES 4
JRPD
Update: having spent some time on a call with Samsung, a reset of the SmartHub fixed download speed in general, now showing on speedtest.net as 70mbps. But Netflix still streaming at 6mbps. (I have an ultraHD Netflix account which gets me 4k speeds on other devices.) Frustrating!
ecosse01
Voyager
Reinstall all apps, including Netflix incase they're caching.
JRPD
Thanks for the suggestion. But I've tried that, and also resetting the Smart Hub, with no success.
JRPD
