What is the difference between tv models UE55TU7000KXXU and UE55TU7020KXXU?
(Topic created on: 26-11-2020 07:29 PM)
Ash3108
Hi, can someone please help me? I was looking at tv model UE55TU7000KXXU (55 inch Smart 4k UHD HDR LED Freeview) but ended up buying model UE55TU7020KXXU (also 55 inch Smart 4k UHD HDR LED Freeview) which was originally £50 more expensive but ended up being cheaper in the Black Friday sale. I want to know the difference between the models but can't find this info. Does anyone know? Thanks :smiling-face:
3 REPLIES 3
AndrewL
@Ash3108: I've had a look into this for you, and both models are identical, with the only notable exceptions being that the TU7000 supports Bluetooth 4.2 connectivity and a feature called Sound Connect, while the TU7020 doesn't. You also get a higher Peak Luminance Ratio on the TU7000, 90% vs 65%, and a lower yearly energy consumption level. For a full breakdown of the specs for both models, please check the links below.
TU7000: https://www.samsung.com/uk/tvs/uhd-4k-tv/tu7000-55-inch-crystal-uhd-smart-tv-ue55tu7000kxxu/#specs
TU7020: https://www.samsung.com/uk/tvs/uhd-4k-tv/tu7020-55-inch-crystal-uhd-smart-tv-ue55tu7020kxxu/
Ash3108
OK, so the TU7000 is technically better - strange that it is originally the cheaper model then? I feel a bit cheated now 😂
Thank you Andrew!
Ash3108
thank you!
