connect TV to internet using samsung lan adapter
(Topic created on: 26-11-2020 06:55 PM)
Del348
Hi
I have a UE40K5100 TV the manual says i need a samsung lan adapter wis12ABGNX to connect to internet
got that.
pluged it into the only usb port on right side of TV switched on went to menu,network,network settings
tv says no samsung lan adapter connected, but it is ive made sure its in correct way and secure
tried resetting tv, no difference
checked lan adapter its real, can anyone help with what to do next please
3 REPLIES 3
AndrewL
@Del348: Sorry to hear that you're having trouble connecting your TV to your wireless router using the recommended LAN adapter. Please can you take a look at page 18 of the user manual via the link below, and check the Wireless Network Precautions, and Network Security Protocols to ensure that your router meets the necessary specifications.
https://downloadcenter.samsung.com/content/EM/201607/20160728120134302/UK5100B_XU_BN68-07408A-02_ENG...
Del348
Yes it does
when the adapter is plugged into tv the tv does not seem to know it’s plugged in as it say to connect use a Samsung lan adapter which I am using and is plugged in
Del348
Andrew
Any other suggestions
