Wall mount QN800A with one connect box behind screen
(Topic created on: 27-12-2021 09:50 AM)
nipmads
hi there
Just purchased the 75" QN800A TV (waiting for it to arrive) the only "grievance" I have is the One connect box. It is to be mounted to the wall - and power/LAN is prepared for behind the TV - so I want to mount the TV with the one connect box behind it - however I cannot find anything to anything having done this?
I like to have a clean look - and have no option to mount the connect box elsewhere. Also a "hole" in the wall isn't an option (hard-wall)
Any input is appreciated.
Thanks 🙂
1 REPLY 1
Erniem64
I have a similar dillema and looking to use gravel board clips to hold it against the wall
