Universal remote Microlab connection
(Topic created on: 23-03-2022 11:40 AM)
stefc1
Hi,
I have a Samsung QN95A 2021 QLED TV and I have connected a pair of Microlab SOLO6C speakers via Toslink.
Using the Universal Remote function I would like to control my speaker set with the Samsung remote.
On the Universal Remote menu, under Home Theater, I can find the Microlab brand and the "SOLO6C" model but the remote fails the power test. I understand from this finding that the model's IR codes should be fully supported.
The speakers are right near the TV, I am trying the pairing process less than 2 meters from them and there is a clear line of sight in between them.
Does anybody have any ideas how can I pair the Samsung remote successfully with this speaker set?
Thanks!
0 REPLIES 0
