UE70TU7100KXXU LCD screen replacement
(Topic created on: 26-03-2024 01:46 AM)
Joe1974
I have recently acquired a Samsung ue70tu7100kxxu,  it has a cracked screen only in the corner I'm looking to replace the screen from a Samsung UE70TU7110kxxu, I've read up on it and it seems to be the same screen across all models, is this correct and if I undertake the task will the screen be compatible,it seems it is I would just ask here for a little conformation..
The 7100 originally was looping with black screen, this is a motherboard issue and has been rectified . I just ask for some clarification on screen swap...
Many thanks to all of you can advise...
1 REPLY 1
Gurky
Helping Hand
I think you'll struggle for a screen TU is 4 years old? And 70" isn't common anymore. You need a specific screen for that TV one that a edge lit LED.
A new modern model would be CU7100 at £719. Much newer and worth taking about when comes to cost of the Screen.
