Salta alla soluzione RISOLTO
UE55KU6500 using onboard Freeview and Freesat tuners together - is this possible?
(Argomento creato il giorno: 24-03-2017 12:40 PM)
29203 Visualizzazioni
philips
Hi There,
Recently purchased above TV and wondered if it is possible to setup both Freeview and Freesat together - or can I only have one or the other to view TV channels. I have connected cables to TV for both Freeview and Freesat and am currently viewing via Freeview and unable to locate an option to then tune in Freesat channels.
Many Thanks in anticipation
1 Soluzione
Soluzioni accettate
Soluzione
KellyM
Helping Hand
Hey @philips,
If you press the Channel List button on your remote control, you should be given the option to switch the Aerial Type. This will allow you to switch between Freeview and Freesat. :smileyhappy:
2 Risposte
Soluzione
KellyM
Helping Hand
Hey @philips,
philips
Hi @KellyM
Apologies for the delay in getting back to you - many thanks for your advice - yes that seems to work a treat
