Go to solution Solved
UE50TU7100KXXU Dimensions
(Topic created on: 15-07-2022 12:47 PM)
benm61
Hi,
Apologies for the completely random question and my usual googling skills have failed me.
I have the UE50TU7100KXXU currently in storage due to moving house so I can’t measure it myself. I need to buy a new tv unit. I can find the width of the tv but not the distance between the legs. I don’t mind if it overhangs slightly so it’s just that measurement I need.
I don’t suppose anyone has that info ?
Many Thanks
2 Solutions
AndrewL
@benm61: As the TU7100 is no longer available on our website, I have been unable to locate the dimensions for this model. What I did do was take a look at the next model in the same range of Crystal UHD TVs, the TU7020, and found the following measurements - 1115.8 x 718.6 x 250.2 mm (W x H x D). As we're focusing on the width of the set, the specs should be very similar, if not identical.
If you take a look at the picture of the set in the link below, you can get an idea of the distance between the 2 feet. Based on this I'd say that your TV stand will need to be a minimum of 1 metre wide, just to be on the safe side.
https://www.samsung.com/uk/support/model/UE50TU7100KXXU/#link
Ginga_p
Hotshot
With Stand HxWxD (Mm)H719.1mm X W1116.8mm X D250.2mm
G G
3 REPLIES 3
AndrewL
Ginga_p
Hotshot
G G
benm61
Fantastic. Thanks for your help.
