Samsung tv model UE50TU7100KXXU buzzing
(Topic created on: 02-11-2023 09:55 PM)
Members_e8rv0CP
So my TV has recently started buzzing whenever dark images come across either all or part of the screen.
My wife and I noticed it the other day when watching Netflix and now I've started noticing it when on my Xbox.
I was just playing a game(jusant incase you're wondering)and was testing moving the camera between a light and dark area of the game and at a certain point the buzzing would start.
The TV is only 3 years old (from when I bought it from very.com)
Is it buggered or is there something I can do.
3 REPLIES 3
JAMES4578
Samsung Members Star ★★
@Members_e8rv0CP It could be an issue with the fan, lack of ventilation or insecure cable connection for instance.    Some troubleshooting here samsung-tv-makes-buzzing-crackling-or-humming-sound
However also check you have the latest firmware and run the Sound and signal tests in Support-Self Diagnosis. possibly you may need to contact support.
anistar
I have the same problem, I was watching netflix and heard a little pop sound from the TV. Ever since it just keeps buzzing. Luckily I've had the TV under a year from argos so will be contacting them for a replacement. Also, I bought this TV as a replacement for hisense which also had sound problems within the year.
Lee Jamieson
Hi, would love to know what the outcome of this was. I’ve had my new Samsung TV for 6 weeks and it’s all of a sudden started doing the exact same thing. Was the fault on your TV diagnosed?
