ue49mu6500 sound setting
(Topic created on: 29-06-2018 12:58 AM)
Edgie70
Troubleshooter
Hi all , just purchased the Samsung ue49mu6500 TV , I like it apart from in sound settings I set it to DTS sound via optical , press the enter button but then when I go back in to sound settings the TV has defaulted back to Dolby , iam running a sound bar that is dts compatible ,  anyone have similar problem ?
3 REPLIES 3
paul1277
Black Belt
Most stuff is odd dd 5.1 not dts so it is auto switching.
Paul
Edgie70
Troubleshooter
Thanks for your reply , I can't believe tho that it won't stay set on the setting I want it to tho
paul1277
Black Belt
If the program is in filmed in dd 5.1 then its good it switches. Most dts are from bluray .
