21-04-2022 12:55 PM in
TVHi, the equaliser on my smart TV has suddenly stopped working. I have tried resetting sound and taking back to factory settings. I contacted Samsung via chat and they had no solutions other than to pay for a costly 'repair'. The only thing that I can put it down to is the ITV app does not work on this model of TV and after I tried to use it the sound on my TV went crazy - loud, echoey and distorted. It also made the picture juddery and out of sync. I had to to do channel reset to get it back to normal. The equaliser definitely used to work! Any ideas? Thank you.
21-04-2022 02:20 PM in
TV@janeyjaney: The Equaliser will be greyed out and unavailable when some Sound Modes are active. If you head to Settings > Sound > Sound Mode, and set this to 'Standard', you should then be able to access the Equaliser via Sound > Expert Settings > Equaliser. Please close any apps you have open when attempting these steps, as this can also restrict access to some picture and sound settings.
21-04-2022 02:37 PM in
TVHi Andrew, no it's not greyed out. Altering the equaliser settings makes no difference whatsoever. They used to work and I simply don't understand why they don't now. TV sounds rubbish without more bass.
