TV won’t come on
(Topic created on: 20-01-2019 08:42 AM)
Alexis28
When I turn my tv on it jumps between the Samsung logo screen and hdmi/dvi screen continuously. It won’t let me do any thing and I can turn it off from that point unless I unplug it. I have disconnected the hdmi leads so nothing is now connected to it apart from the power cable. Any suggestions?
7 REPLIES 7
AndrewL
@Alexis28: Please can you confirm the model number of your TV? When and where was it purchased?
Alexis28
Curry’s in Luton roughly 4 years ago.
Model code: UE37D5520RKXXU
AndrewL
To troubleshoot the issue please ensure the Sleep Timer is off by going to Menu > System > Time > Sleep Timer. If your TV continues to reset then I recommend getting in touch with the Samsung AV Team on 0330 726 7864 where an advisor will be able to provide further assistance and arrange any necessary repairs.
Alexis28
The tv won’t even let me go to menu. It doesn’t recognise any buttons that I press
CarlH
It would be best if you contacted support on the previous number in that case, @Alexis28
paul1277
Black Belt
How old is it,  and more importantly have you reported this to your retailer,  who are responsible under consumer law.  Here is ok for advice but you always need to report any fault to your retailer in the first instance.
Gussvontesse
Same thing withwithy TV. Send a lot of people experiencing this problem and Samsung does nothing about it .😕
