TV White Line bottom edge of screen... help
(Topic created on: 29-05-2020 07:39 PM)
FenKev
Dear All
my Samsung wide screen has a bright section along the bottom edge of the screen. It is the length of the main remote long and it looks like a light shining up from the edge making that area brighter. Any ideas on how to fix?
It's updated.
Did the pictures test and the light spot / line remained all 3 times so failed to fix.
7 REPLIES 7
TessM
Mastermind
Hi @FenKev ,
if the TV didn't pass the Picture Test the next steps would be having this examined by one engineer. To find your nearest one you will need to reach Support in your region: https://www.samsung.com/uk/function/ipredirection/ipredirectionLocalList/
FenKev
How do I know if it’s covered by warranty?
TessM
Mastermind
All our TVs are covered under a 12-months warranty. When and where did you get yours?
FenKev
Not sure but over 12mths, I guess it'll be bett r to leave it and then replace TV once it gets worse
Peter155
I have exactly the same problem with my Q7 series. Could be an issue with the latest OS?
erykpiast
I have a similar issue for a week now. Model QE55Q7F, 2.5 years old.
FenKev
Mine is a similar age, very annoying and happened all of a sudden not a gradual process. I've had quite a few Samsung TVs but when I replace this one I will probably look at other brands. I didn't mind paying more for a Samsung because I thought I was buying quality but it they go wrong so quickly probably not a great investment:(
